Discussion Starter · #2 ·
10 hrs left
less then an hr on clock. last call
mad jdm tyte yo. yea, thats half the problem. anyway, its still on sale, reserve of 250 wasn't met on ebay. its brand new, and never installed so someone jump on this. heres the specs.
Product Description:
The A4 is the perfect adjustable racing seat for tight spaces and minimal headroom applications. Whether on the street, the track, or off-road, the A4 racing seat will enhance your overall driving experience. As a rule of thumb, the A4 will fit up to a 34-36 inch waist while the A4 Wide will fit up to a 38-40 inch waist. High wear patches are strategically placed to protect your seat from abuse in the high wear areas.
Features:
Infinite recline: The fingertip controlled reclining mechanism allows the seat back to be adjusted to the ultimate driving position. Corbeau reclining technology allows with just the lift of the lever, the seat back to be immediately returned to the full upright position.
Bolster Support: Ultimate lateral support with well-defined thigh, kidney, and shoulder bolsters will allow both the driver and passenger to remain in the optimal seating position. The reduction of body shifting will reduce the amount of driver fatigue and enhance the overall driving experience.
Harness Capability: This seat has harness slots for 3 and 4-point harness belt capability. A submarine slot (5th slot) can be added to the seat base for a $29.00 charge. This slot will create 5-point harness capability.
Injection Molded Foam: High-density injection molded foam provides ultimate comfort. The heat transfer into the foam causes the seat to form to your body. The foam will maintain its shape for years insuring long lasting comfort.
Fabric: Anti-slip cloth and microsuede materials coupled with anti-wear patches. Contains UV inhibitors. 100% automotive grade leather also available. This seat has been extensively tested under extreme conditions and found to be colorfast.
Steel Frame: Extra strong, lightweight, powder coated tubular steel frame.
