1 - 18 of 18 Posts
techgeekwill said:
was this front or rear?
Does it make vibration worse or better? I don't remember the details on this.
its the front, yes you will notice some vibrations at idle
Is this pretty easy to install? Just unbolt and lift up the engine right?
you dont have to lift the engine, just onbolt the two bottom bolts and the center bolt and swap the out in that little time the bolts should line up with no problems
how long was this used?
50 shipped?
1 - 18 of 18 Posts
