1 - 3 of 3 Posts
Some body stole this 2000 celica gt from owner wen it was relieved they had broken the ignition and had the switch hanging with wires direct to solenoid for starting also I believe the key buzzer wire hanging down next to the starter wire .went to start vehicular and accidently. Touched the hot wire to the key buzzer now my fuel guage only shows wen the hight lights are pulled to the passing position and help would be appreciated
Are you referring to the backlight for the gauge or the pointers? Definitely an odd issue. I suspect that you may end up having to replace the Body ECU.
I would agree with 2way.. Body ECU... A while back my fuel gauge wasn't visible either, nor my door locks, tail lights and moonroof among other things I don't remember to worked. Swapping the body ECU fixed most issues.. I picked up a few at the salvage yard just in case.. Play your cards right and they're $10, wrong person though and it will be around $60....
1 - 3 of 3 Posts
