yeah but that built in fuse is to protect the wire from shorting. do the amps have a built in fuse on them? the amps should say what size fuse they need. what you do is have a main fuse by the battery, a wiring kit shoud come with one. ususally 4 gauge comes with a 60 amp fuse. then when you split it into two 8 gauge wires to go to the two amps, you use a fused splitter, and i'd put fuses there at whatever your amps are rated at.
