1 - 3 of 3 Posts
Should there be a gasket between where the header meets the part that is attached to the turbo on the SF kit. The flange im talking about is the one that is bolted together on the manifold with 4 bolts/nuts. It is just 2 pieces of metal together, and this doesn't seem right.....
No thats the way it comes....there should be some sealant between them...as long as you dont seperate them, you should be fine
there was no sealant between them when i took them apart. I took them apart to get the header part ceramic coated. So would liquid copper gasket be good enough between the two pieces?
1 - 3 of 3 Posts
