1 - 4 of 4 Posts
Hee guys,
Does anyone happen to have a schematic of the gauge cluster?
Not just the pinning, I mean the real schematic
Or maybe some kind of PCB layout
A Hi-res pic of the board would also be appreciated:)
Thnx!
· Electromagnetic Wave :-h
They don't go down that far in detail. You might try LEDMod for pics and info. Otherwise, you have to reverse engineer it. Is there something in particular you are trying to do?
Hee 2way!
I was hoping you would post here
There're several things I'd like to modify actually.
Basic things such as swapping the LED's
So I would like to know the voltage of the LED's as well as the light output
And I would also like to use an LED (or LED's) instead of the annoying beeping when you're in reverse.
But I would also like to look into making a little display as speedometer
Like this:
Check w/LEDMod. He'd be your best bet.
1 - 4 of 4 Posts
