well lads just a question for yas did yas have any problems or know one that had any problems with the 2zz ge gearbox 6 spd..
when i bought my car there was a slight noise coming from the gearbox, whenver ya wher in 2nd, 3rd or 4th gear and rev'd over 4k revs and let off the accelerator and whinning noise came from the gearbox so i took out the gearbox and took it over to a toyota specialist and turned out the bearings wher in bad shap and 5th and 6th gears wher fooked it was goin to cost around 1300 euros to fix so i got a 2nd hand gearbox and it was a good one so i just opened it up and put in my trd helical lsd into it and fitted it back into my car and few weeks down the line the noise came back again...
i know the sinchro mess gears can go on these but just wandering have any of yas have had this problem
also what gear oil do you use take note has to be limited slip diff oil
cheers
That noise is normal, simply differential chatter.
so its really nothin to worry about right only thing that gets me is its only in certain gears and revs
It may not be the gearbox dude, noise on these can travel, spose you should check the oil seals, look for signs of past leaks under, also lubricate the linkage assembly whilst you are down there too.
____________________________
What is the Best Auto Motto?
car is due a service next few weeks so have new gearbox oil for it got it from fensport and then just get the mechanic to check all around it
