1 - 10 of 10 Posts
getting cel from doing the butterfly mod & i double check everything is connected. the instructions say i should plug one of the hoses.. but the instructions is kind of confusing.. could it be one of the hoses i didn't plug that caused a cel??
9) Pull off the hose that is attached to
the butterfly valve and plug the end of the hose up!
10) Slide the Butterfly valve straight
up. It has two clips on the bottom (can be reached by
hand under bottom of intake) that need moved slightly to
allow the butterfly to come loose.
11) Place the butterfly hose back in the
same slot that it came out of. As to not interfere with
other moving parts of the motor.
your the first person i've read about to screw up the butterfly mod..try resetting your battery and see if the cell comes back if it does put the butterfly back in and see if it goes away. if it doesnt you missed a step
i actually have to agree. i havent met anyone who had the issue ;) but yea remove battery negative for liek 10 min and see what happens. sounds like that tube isnt sealed well enough. i used a large screw and electrical tape w/o issues :)
There is a small vacuum nipple on the intake manifold in front of the throttle body - thats what you need to cap or plug.
stupid me... after i posted i realize i forgot to reset the ecu by unplugging the ground from the battery, i guess that's what happens when i work on my car before i have to go to work..
are you glad you did the mod? i heard it gives more bogging from 0-4k rpm and only better top end performance. Are you still running stock airbox?
you heard it right. there is a dead spot between ~3200-4000rpm on my car and its quite noticeable. i'd rather have my low end torque back than a little gain in hp up top. PO removed it.
i dont understand why you have to clog the hose... what it you leave it attached, what happens?
What is that nipple's purpose? Like, where does the hose that is attached to it go?
There's no bogging at all when I did this mod, sure is safer then when I had my cai lol. I'll probably get a sri soon with a heat shield. Would a sri with heat shield have more performance gain then doing the butterfly mod? Not looking at cai anymore btw. Anyone can help, let me know, thanks.
1 - 10 of 10 Posts
