nope just get the compression test. My instructions weren't clear enough last time? here let me put it in step by step.
1. take off plastic valve cover
2. unplug all coil packs and take all four coils out, place somewhere safe
3. take out all spark plugs and place somewhere safe. to take out the spark plugs you will need a spark plug socket and at least a 8 inch extension for your ratchet.
4. screw compression tester into cylinder 1, get a friend to crank your engine while you read the gauge, turn the key on like you are about to start the car, leave it cranking until gauge stops, the car won't start because there aren't any spark plugs to start the car. once the gauge stops moving then you know what your compression is.
5. repeat on the rest of the cylinders. compression should be 220 on a 2zz.
6. If compression is lower than 220, then you should do a wet test.
7. wet test, take a teaspoon of oil and dump it into the cylinder through the spark plug hole. let the oil settle for a bit, maybe 1-2 minutes then redo the compression test.
8. if compression is still low, then you know you bent a valve, if compression raises, then you know you have bad rings.
9. if compression is still low after you do the wet test, then you need to do a leak down test to see which valve is bent.
10. put all spark plugs back, and put all coil packs back.
