1 - 7 of 7 Posts
so i jus finished my engine swap and had a toyota mechanic take apart my 6-speed trany. drove the car from 1 to 6th gear and its perfect until i downshift into 4th....wats goin on? do i need a new sleeve and synchro?
Mines been doing this for months. You get used to it. When you need to go down to fourth, go into third and then it'll pop down to fourth.
ive had a 2000 gts fr about 2 years been doing that since i got it.
mines been doing the same thing, if it annoys u, do wat sickcelica says, go into third and then shift into fourth, or go into neutral release ur clutch, then press clutch back in and go into fourth
12+ years daily driver
my transmission did this. Swap the fluid with redline mt-90. When I did, it took my grind away for good.
have you tried rev matching, or going into 3rd first before hitting 4th gear? If you go 3-4 its a different fork than downshifting into 4th, so it shouldn't grind.
1 - 7 of 7 Posts
