Hee Guys
I was wondering if the gauge cluster of a GTS would work in my GT?
I know the difference between the prefacelift and the facelift versions
I've got a facelift
And the GTS cluster I would be getting is also a facelift
So no problems on that side
But would the GTS cluster work properly on my GT?
Thanks!
O_o
Yes, your redline will be off though, and the odometer follows the cluster.
Why do you want a GT-S cluster anyway?
Nice:)
I can swap the chip containing the odometer info
So that won't be a problem
I'm working on some mods
And considering a 2zz swap
So I'd like to gatter some GTS parts one by one
Starting with small things, such as GTS pedal and the gauge cluster
Since I got a EU spec facelift GT
I already got TRC and VSC
So the difference between my GT and a GTS is only the engine (and ECU and stuff)
Thanks!:)
Hey Uranus,
How do you swap the chip on the gauge cluster? i am having problem with my cluster and want to swap it out.
Hee hlee83,
I haven't tried this yet. But I've been told you need do swap this chip:
