1 - 14 of 14 Posts
So, I've been reading about how HID installs into the stock halogen assembly can reveal the "UFO holes" that are present in the halogen assemblies and not the HID ones. I'm running stock halogens but my right projector seems to be either misaligned or damaged as I see the UFO's on that headlight. Left one is perfectly fine. Wat do?
It looks so happy....
Bulb is installed wrong, it's cocked at an angle in the housing.
Whoever replaced it wasn't paying attn. to how they put it back in. Is the wire holding the bulb in place or the rubber boot.
They are a PITA to replace in place.
Not entirely sure how the bulb is cocked. If I remember correctly, you gotta remove the bumper to get to all the mounting brackets and get at the bulb, right? How long would it take to get that set properly?
You don't have to remove the bumper. The projectors are at the top of the headlight. You need to remove the L-shape engine plastic to see it. The most likely reason is the bulb not beeing properly in place in the housing as mentioned.
Damn, well I tried to remove the headlight and ran into some trouble. So for the right side headlight, once you remove the two 10mm bolts and disconnect the tab from the washer fluid clip, are you just supposed to lift and it'll come out? If so, something's up. I can't seem to pull the headlight out.
1 - 14 of 14 Posts
