Here's a better explanation. I guess I should have posted this up earlier. This is a common mod in the Nissan community. Bare in mind this is for a 240SX.
The theory:
To run bigger injectors without an S-AFC or upgraded ECU on a KA24DE turbo, you can 'hack' your stock Mass Air Flow Sensor (aka MAF) to sneak a proportionate amount of extra air into the motor to match the extra fuel being sprayed due to bigger injectors.
If you want to run bigger injectors (say the 370cc side feeds form an SR or Z32 TT motor) you need to compensate somehow, otherwise you'll run VERY rich, and have poor performance.
The easy ways to accomplish in the past was to get an Apex'i S-AFC, which is a piggy-back controller that alters the airflow meter signal before it gets to the ECU and tricks the computer into spraying less fuel as desired...
To understand how this works, you need to understand how the Nissan MAF works - It has a hot wire in it that sees a cerain voltage. As air passes over the wire, it cools it, and the ECU sends more voltage to try and keep the wire a constant temperature. Based on the amount of voltage needed to sustain a certain temp, the ECU determines the total mass of air entering the motor. But it works based on a few assumtions, one of which is the cross sectional area of the MAF tube.
So if we increase the cross sectional area by some percentage, we get that much more air entering the system unmetered...so it can compensate for the extra fuel being dumped by the larger injectors.
An example:
370cc injectors are 37% larger than stock [270 * 1.37 = 370]
So we need 37% more cross sectional area in the MAF tube to be close to being "calibrated"...
Remember, the area of a circle is [ Pi * radius^2 ]
So we need to know the stock S14 KA MAF inner diameter (ID).
By my best measurement, it's 2 29/64", or 2.453". Divide by 2 to get the radius (1.2265"). Square the radius, multiply by 'Pi' (3.1416), and you have the stock cross sectional area:
1.2265 * 1.2265 = 1.5043 * 3.1416 = 4.7259 square inches
Now, increase that by the same increase in the injector size (37% in this example), then divide by Pi, and take the square root, and multiply by 2 to get the new, recalibrated ID.
4.7259 * 1.37 = 6.4745 / 3.1416 = 2.0609 [square root] = 1.4356" * 2 = 2.8711" ID
So theoretically we need a 2.87" ID tube - Conveniently, some 3" exhaust tubing is 3" outer diameter with 1/16" wall thickness, leaving 2.875" ID...
But I have found, with more and more testing, that 2.875" ID is too lean. Apparently the hack introduces enough inaccuracy that we need to be bit smaller to keep a proper A/F - I had to play around A LOT to figure out what worked for my setup, which is ~2.75" ID.
So we have an *almost* exact tube, for relatively cheap, and easy to find. Now you just hack your MAF down to nothing but the square box on top and the hot-wire sensor, and insert it into the 3" tube in the same manner as it was installed form the factory. JB Weld works well for this...
