ok so I have a 2000 celica GT with 125,000 miles on it. recently I have been having some issues....
low horsepower,
oil consumption,
vacuum leaks from air intake,
and a few other minor things..
so my fiances sisters boyfriend works on cars and he offered to help me replace all the gaskets.
here's what happened.
car ran fine for 1 day and then check engine light came on i checked the oil and it was MOCHA colored!!! obviously the had gasket went bad... this happened because thinking back he did a number of things wrong that I didn't realize.
1st he put the head gasket on with a ton of gasket sealer and used his finger to smooth it out which wasn't very smooth. then he let it sit on there to dry and then he put gasket sealer on the head and waited for that to dry and then put the camshaft head on top of the lower engine block.
2nd he ripped it back off bc he forgot something and he didn't fully clean off the gasket sealer that was on the blocks or the gasket. ( he did most of it but he used a flathead so now there's little tiny scratches on the blocks) they aren't gouges there just little streaks but still, am i going to have to get those scratches polished out?
3rd when he took the 2 blocks apart the gasket split from its 2 pieces and the 1 end about an inch. i was told it wouldn't matter if it split yah stupid!!!!
4th he used 3 tubes of gasket sealer for the whole gasket repair from the head gasket up.. head gasket, timing case, water pump. valve cover gaskets, intake gasket. that seems like that's way way way too much for a 4 cyl.
5th the headbolts he didn't use a torque wrench to tighten them to spec. he just "feeled" for it yah i know. On the Manual it says to tighten them down to 33 Ft Lbs, that doesnt seem like alot however the book should be right? right?
i'm starting to sound like such an idiot for listening to him but i dont know too much about cars im in the medical profession so i just took his word, well obviously that didnt work. sooo question is
do I NOT put gasket sealer on head gasket? Do I have to polish the heads where they meet? DO I follow the celica Manual from the site absolutely to a T especially when it comes to torque. (can the book be wrong)
i just need as much help as i can get this is my only car now I'm bumming rides.
low horsepower,
oil consumption,
