1 - 8 of 8 Posts
I found a few places that sell the mounting kit for single din headunits, so Im just wondering if there is any advise as to any that are better than others.. did anyone order them off the net? also
the one i found @ sounddomain.com says 2000-UP Celica / Echo for the mouting kit, and the wiring kit says for 1987-UP Toyota..
can anyone confirm that these would be correct?
here is the dash kit
also anywhere on the web where there are details about how to take the dask apart for headunit install??
thanks
That's the one I bought. There are a couple of brands, personally I like Scosche or Metra. They both do the job. As for the removal of the center console...its easy:
1. pull up where the shifter surround is, just in front of the power window switch,
2. unplug cig lighter
3. take the 2 screws in the bottom of the AC controls off
4. take off the AC knobs (all), and remove the 2 screws behind the temp/air knobs
5. pull up the whole assembly up and out, and unplug the clock.
6. remove 4 bolts holding radio.
7. reverse for reinstallation.
If I missed something please someone remind me...:gap:
there is a new version of the wiring kit that is available for the celica. x-evil-x has it so try pming him
Discussion Starter #4
what is "new" about it? I am not looking to change anything else about the stereo at this time but the headunit.. so how would 1 wire harness be better than the next? Is there any considerable difference that you know of?
Discussion Starter #5
thanks for the info.. this should help me out
what's "new" about it is that it allows you to use an aftermarket HU with the OEM amp, any other harness won't let you do that. So if you are planning on keeping the OEM amp (of course if you have the GTS system) then you NEED that wire harness that x has..
Do you guys think there's a big difference between the stock HU from an aftermarket HU?
1 - 8 of 8 Posts
