1 - 10 of 10 Posts
OK so i changed the engine about a month ago for used 2zz, everything was fine until tonight. I was exiting a parking lot & was switching from 2nd - 3rd gear when I heard a a noise that sounded like it hit a tire on the road or something. emediately after my power steering went out, my check battery light came on & I couldnt engage 2nd gear. I drove it fore about 2 blocks pulle dover & noted that the belts on the passenger side were trashed!
Help! has anyone had the same problem??? What is it & how much will it set me back to fix.
Again the belts are ripped, power steering went out, Im having hard time getting it in gear & the check battery light is on???? engine still running & sounds fine????
Ultraviolent
should be ok, saves you having to take off the old one:chuckles: get a new one and follow the steps thats in the INSTALLS section
well the power steering and battery light is because of the belt...since the PS and alt is ran by that.
Its the serpentine belt! Replace it yourself. A gatorback one costs about 35. Pretty cheap!
I took it to the shop & found out my ac compressor came loose. It has 3 screws & one of the brackets were broken o the block when i replaced the engine. i thought 2 would be good but obviously not! How can I fix this from happeing again??
Broken mount on engine for ac compresor. How can i fix it so the ac compressor dosent come loose again.
Well you need to fix the mount and put the correct amount of bolts in...torque them to spec.
1 - 10 of 10 Posts
