I was given a ticket to appear at our california state referee for modified exhaust & intake so I put the car back together with oem parts but failed the inspection & emmissions test. I replaced my intake & catback. The original cat was never tampered with . But I did replace my 2zz & i think the shop didnt hook everything up. But I have been told the fact my gar is so rich has nothing to do with my air intake & my check engine light usually stays on but since replacing the cai with stock air box it is on 1/2 the times & will stay off for days.
PLEASE, PLEASE HELP ME TROUBLE SHOOT THIS SO IT DOSENT HURT MY POCKETS & AVOID GETTING RIPPED OFF BY MECHANICS! ANY InExPEnSIve SMOG/RepAIR SHOps? ANY TIPS/HELP WILL BE APPRECIATED!!!
Here is what they found "this is exactly what it said on the report":
Fuel Evaporation System (EVAP)
* Install/replace/Properly Route Vacuume Hoses
route vac lines according to vac diagram.
Miscellaneous Emission controls
*Install/repair vacuum Hose Routing
route vac lines according to under hood label
*Check/repair High Hc Emmisions
diagnore & repair hc emmissions
*Other
vac line to vsv disconnected
*Check & repair NOx emissions
diagnore & repair NOx emmissions
HERE ARE PICTURES OF THE ACTUAL FAIL SMOG/EMMSSIONS TEST:
