Guys, I just started working on my audio system. I just got 3 10in ALpine Type R's(1041D)
Spec of the subs:
4ohm+4ohm
1000w peak
300 RMS
What amp you guys recommend that I should use to run this? As much as possible i want it ALL to be alpine components, just cant seem to find the right amp to run this.
uh alpine amps are kinda weak, you won't find one that puts out 900w rms. thats why i'm not a big fan of theirs amps, they're pretty expensive for not being very powerful. you'll be at 2.7 ohms. if you go with another brand i like jl but you have lots of choices. jl, eclipse, etc. the best value amp would be jbl. i'm sure all those brands would have a good match for you. just make sure they're 2 ohm mono stable.
howd you know that im at 2.7ohm(me newbie). JL sounds good and matches my color scheme. Is there a JL amp that can run my subs? why does it have to be 2ohm mono stable?
zapco
Discussion Starter #5
nevermind...i returned my R's got my something else, inluding 2 amps and 2 capacitors. Thanks for all the info though
