1 - 8 of 8 Posts
Hey guys I have a bit of problem with my built 2zz Celica the lift like bogs and then goes into lift but doesn't feel like it hits lift I been searching around but I couldn't find anything I checked both ocv screens and the solenoids but they seem fine...thank you (Mods- mahle 10.5 pistons-are head studs- turbo kit-850cc fuel injectors-alexis power fc)
It looks like lift bolts problem
Sticking solenoid or Lift bolts
Do you have a stock ecu?
Sorry. I just saw pfc
Did you have that problem from the beggining of pfc?
There is a choice on pfc (if you you dont have have datalogit you can use commander) that is for low lift and high lift. Low lift must be a bit lower than high lift. If by accident they are opposite you will have the problem that you discribe. Check that first
1 - 8 of 8 Posts
