HI SO IM NEW TO THIS SITE BUT I NEED HELP ANYWAYS I BOUGHT A 2000 celica gts I knew it had issues but just realized they (previous owner) had tried swapping the engine out this car is a 2000 automatic celica gts the hood has 2zzge stamped as the engine that should be in it after a little research I can clearly see what's going on the car was a original 2zzge car then whoever had it before me must of tried swapping it out with the 1zzge by mistake and now I'm stuck with a car that needs a new header for the exhaust because the one that the car originally had doesn't match up with the 1zzfe that it has now I guess my question is would it be cheaper to just keep that 1zzfe and change over what ever I need to run that engine or should I just get a used 2zzge and swap it out engine looks fine but I have not tried to start it at all what and what would I need to do to swap it and make sure it runs smooth if I were to keep it in the car would I need to change the ecu? Any wires or sensors that i might have to alter to keep that engine? Is it even worth it? I got the car super cheap but now I know why lol anyways I am willing to fix it I would appreciate any help thank you
