1 - 8 of 8 Posts
How do you remove the plastic spark plug cover on a GT?
I was going to replace the spark plugs today (just turned 50k) but I could not figure out how to remove the cover. :confused:
I removed the two acorn nuts in the front but how the *#*# do you remove/release the two plastic retainers that secure the rear of the cover? I did not want to break the retainers by forcing anything the wrong way,etc.
Even the repair manual is not any help on this. Help! This has really got me stumpted! :wtf:
there are plastic covers back there??
I don't have anything. Jus the two nuts.
like he said^^^^ i think....but be careful! they're really easy to break! i broke mine when i tried to remove 'em. Until now i've never figured out how to take them out! i put the plastic cover on without them. Oh well... Sorry man, wish i could help u.
Discussion Starter · #5 · (Edited)
OK, thanks for the info.
In the morning, I will try gently prying up the rear of the cover where the retaing clips are located and see what happens.
From what I can see from the limited views in the repair manual, the clips may be of the type that fit into a round hole and are insterted much easier than removed.
I will keep you posted.
Discussion Starter · #7 · (Edited)
That is exactly what I did and what I discovered.
I pried up next to the rear plastic clips with a small screwdriver and they released almost effortlessly! :applaud: They are a simply friction fit clip and a sutable replacement should be avalible at Auto Zone, etc, for those who broke them.
Anyway, thanks to all, you were a big help! :)
BTW, I was surprised that the old plugs were still in relatively good shape after 50k miles.
I replaced them with "Denso IK16" and it does seem to run better, particularly at high RPMs :)
1 - 8 of 8 Posts
