i need the initial settings for it
speed signal pulse
factory tire diameter (i have stock 16 if that helps)
vehicle weight in kg
if theres anything else that would help me wit the install an setting i would appreciate it
you can use the calculator at tirerack.com for the diameter of tire,or just go outside and measure it. your best bet would be to go to a scrapyard(metals not cars) and use thier scales i didnt even get charged for it. the speed pulse thing youre on your own
