Ok ever since i put my new motor in i have been running lean according to my air/fuel gauge. Before it used to search when cruising around but now as soon as i turn the car no it pins to a certain spot in the yellow and dosent move no matter if i punch it (it does go down when i let off) or if im just cruising it just stays there and dosent search. Well because of this my CEL is on and it says i am running lean in bank 1(also says my o2 sensor is malfunctioning). Also i am getting horrible gas mileage and puffs of black smoke come out when i shift. I am pretty sure this is because the computer is trying to correct the leaness and i am running rich.
So my theory is that i missed a ground wire somewhere when i put the new motor in because when we did the swap my a/c wouldnt work (compressor would kick on then shut off and light would blink) but as soon as i cut the ground wire and regrounded it i had no problems at all. So do you think my theory is right and i missed a ground. Does anyone know where the ground for this is or perhaps which wire is the ground on the 02 sensor?
any help will be appreciated.
Rick
Rick
