Ok guys I already have the rear strut out of my car. I have the spring compressed with the proper compressor but I need to get the nut off the top. When I turn the nut, the whole rod spins and it doesn't loosen. There's an alan wrench indent in the top of the rod that the nut is on but using an alan wrench doesn't help because you can't get enough torque on both at the same time. Also, I already broke one of my alan wrenches on it when i propped it against something while i torqued on the nut. and I don't want to break my only other one. It looks like there's threadlock on the nut/rod assembly as well. Will an air impact wrench work? What should I do? I seem to be the only one who has had this problem
