1 - 8 of 8 Posts
For those of you with a WW wing.
I recently got a WW wing w/out the instructions. I need a little help with which screws go where. Here is what I have.
4 little screws. About a 1/2" long. I presume these hold the endplates on
4 allen screws. These require an allen wrench to tighten
4 more screws that require a regular screw driver.
What goes where?
Thanks guys!
the shortest ones will bolt the wing onto the hatch.
the longer ones bolt the middle piece onto the ends.
the allen ones slap on the endplates (im assuming makes it harder for thieves to mess w/ your wing)
btw, do you have the ABS plastic one? holy crap it is nice and LIGHT! the design looks much improved over the past ones also. if i didnt get the sports m wing i totally would be happy with the redesigned v-line.
Thank you for the help!
Is there special tool required for the short ones? There are little metal things in the middle making it impossible to use a regular allen wrench on them....
the short ones with the allen holes are security screws. they hold the outside covers on. they are like that because you have to use the supplied security allen wrench. you can buy them some places too. maybe www.securityscrews.com
the longass screws hold the blade on the sides, and are covered by the covers. the ones that are left should have white rubber washers that smash when screwed on to seal it. if you don't have those (probably won't if its used) you should get something like taht to make sure no water gets in.
good luck w/ the fiberglass ones. heh, they fill up with water!
aaaahhhh. That makes a little more sense now. How big are the white rubber washers? Are they about 1/8 to 1/4 inch? I don't have those damn things!
I guess I will have to buy some rubber washers!
Thanks again for your help guys!
1 - 8 of 8 Posts
