OK, so I purchased a set of 6000K HIDs from another member on the board, and it does not seem like the bulbs are as bright or colorful as they should be(the right side has a bit of a yellow hue to it) and now I want 4300K bulbs. Being it that I got the set for a good deal and it came with Hella ballasts. Here is a picture of the exact kit:
Now, I have a few questions:
1. Will this harness work in order for me to convert my ballasts to hold a D2S bulb?
2. If not, is there another harness that I can purchase that will connect directly to the ballast rather than converting it from the AMP connectors?
3. Since it is a Hella ballast, isn't it supposed to have a separate 12V wire in order to collect power directly from the battery rather than using the stock harness?
4. How can I tell if it has built in ignitors?
Thanks.
Thanks.
