Anyone know? I've pretty much decided on getting BCs.. Just wondering what the highest height setting is (for winter).
Maybe someone measured how much lower it is compared to stock height in BC's highest height?
Is this for the front and rear? Sorry, I know the thread is old.
I assume the coilovers will just stop spinning when they reach the top. I was thinking of just leaving the front on the highest 1.5" setting and putting the rear at 2.0-2.5". If they are both the same that will make it easy to adjust. Just set the rear .5 to 1" lower than the top setting once it stops spinning.
EDIT: I don't know if this makes a difference, but I also have the Swift spring upgrade.
ninotnax
I can get you an answer. I will tell you though the back is a big drop compared to the front and I was disappointed because I wanted to remain stock height.
On the rear you need 25 mm to remain in the housing as you unscrew the strut.
Edit: Remember you don't adjust height by raising the spring. That increases the spring preload and can shorten the strut and spring life. You adjust in by turning the strut in and out of the housing.
