1 - 7 of 7 Posts
I just don't know what to say really....
quote:
Prototype is black '93 Z28 with purple flames on front. Sounds like alot of you have seen or heard of the car. Car was at UVSC carshow along with a few of our trucks. Turbo mounts in rear on all our vehicles which raises some eyebrows and always draws in a few sceptics. Our system works real well and has several benefits that come from putting the turbo that far back. First is that this kit installs in about 2 hours and anybody can put it on without hacking up your ride. Second is that our turbo temps are about 500 F cooler than those on underhood applications and that means less heat put into the air charge and lower underhood temps. Plumbing charge to the front provides a very efficient intercooler without the typical pressure drop accross conventional intercoolers, Won't go into the rest right now. Prototype did pick up 14 mph in quarter mile and car ran 13.0 at this elevation at 111 mph with moderate 7 psi on street tires w/ 2.73 gears and automatic (car is totally stock other than our system). Engineer from Garrett came up last week to check out our systems and was very impressed with all aspects of the kits. Said our Camaro was one of the fastest cars he'd ridden in. Everyone is concerned about turbo lag with turbo so far back. Not the case, our system is designed to operate with turbo in this position and has hardly any lag. Will break the tires loose at about 40 mph. Have car set up to run 10 psi w/ water injection at the flip of a switch. Did dip into 12's but mostly just spins tires real bad. Just got some drag radials and ordering set of 3.73's w/ converter and shift kit. Car should hit 11's easy. Anyone interested is welcome to come by the shop. We are in Orem.
Yeah, we were talking about this on supraforums. The thing is retarded. When talking about the intake system of a turbocharged car shorter IS better. You know those little floaty things they make for people who can't swim that go around your arms? What's easier to build pressure in, that or a big inner tube? Same applies for building pressure in a car. Having the intake pipe that long only serves to increase lag. The only way to counter it is to make your piping smaller...which hurts air flow. It's really a lose/lose situation.
Oh, and by the time the exhaust gases have reached back that far they've cooled down significantly. I can't remember the science behind it but I do recall the conclusion that it was more effective to spool the turbo with hotter gases then colder.
Well the picture doesnt work but Im pretty sure it must be the Z28 with the turbo right at the rear axles. I can't imagine WTH they were thinking when they did it that way.
1 - 7 of 7 Posts
