Hello Everyone!
After many years in a Neon, I find myself with an 02 Celica GT in my garage.
Mark Hirt and Mike Lillijord (and all that are national level autocrossers, of course) can you guys clue me in on the hot set up for G Stock?
The main concerns are:
Alignment- how much negative camber front and rear?(and how is the negative camber achieved,ie crash bolts,etc) How much toe front and rear? (I hear that you guys run toe"in" in the rear)
Brakes- what is the hot pad?
Tires- What size? (has anyone tried a larger tire in front than in the rear?)
Wheels- what are the lightest with the correct offset (what is the offset anyway?)
Harness- does a Schroth harness work in these?
Exhaust- what gives the most HP and sounds the coolest?
***STRUTS- Dollars are no object here, ONLY the best will do!
Air filter- supposing K&N here.
Plugs and wires-which are best?
Thank you in advance!
Mark Darby
#33 G Stock
02 Celica GT
Mark Darby
#33 G Stock
02 Celica GT
