1 - 4 of 4 Posts
I have put on my hotchkis struts, springs, and front strut bar. I would like to know if I should get an alignment now or wait a week or two so I can put on the sway bars and the rear camber plates. What would be better and and what would be the difference if I got the alignment now? Thanks!
if ur installing rear camber plates .. wait til you get those on. Because when you get an alignment, you will use the camber plates to adjust the camber in the back. If you do it now your just going to be wasting money. Just do it all at once when everythign is on
Thanks!
Rear camber plates? I didn't know there were such a thing. There's hardly any room for adjusting the shocks back there, much less adjusting camber through the use of plates.
The only adjustment aids I've seen are the hotchkis camber links or eibach camber bolts.
1 - 4 of 4 Posts
