1 - 3 of 3 Posts
Now HERE is one i could not find an answer for ANYWHERE.
How much would 1" spacer/adapter weigh? I'm guessing around 1.5 to 1.75lbs?
Just trying to figure out how extra weight it would it would add to a lightweight rim to space it out and look good... as apparently there are NO Toyota rims out there in 17x8" that come anywhere near flush. All the lightweight stuff i find in that size is around 35mm.
Also (while i'm here) Any preferred brands?
hmm... not completely sure but if you have a few weeks to wait I can measure mine for you. H& something is the brand I saw recommended when I bought mine, but I never installed them. I believe that even with ARP studs that 15 or 20 mm is the biggest you can use and 1 inch is 25 mm.
So yea I have a set of 15 mm that I can check when I get back home in early January. ill use the density to estimate the 1 inch weight.
1 - 3 of 3 Posts
