1 - 3 of 3 Posts
how do you install the molly side skirts? i bought them used with no instruction. there are 2 long brackets and a couple small ones. i'm trying to figure which goes with which.
i did some search but no luck.
need some help please!!!
12+ years daily driver
generally speaking, aftermarket sides attach along the bottom and where it meets the inner wheelwell. My trd's clipped in with the factory clips, but my vizage I had to make long and short brackets to hold the skirt tight against the car.
If the brackets you have is the same as what I made, then all you have to do is put the long ones on the outsides, and the short ones in the middle....or however they will fit. Once your laying up under there you can flip/flop them around and see how it holds the tightest fit with the least amount of modification.
1 - 3 of 3 Posts
