1 - 7 of 7 Posts
I just got my Celica like 5 days ago...its a GTS 2001. I was wonder how do i take out the center piece so i can put my old mp3 player in there. Im scared i might break something if i try to pop the center piece out. Is there instruction on how to take it out? can someone help me thanks!!;)
-Pop trim around shifter, pull from the rear up.
-unplug cig lighter
-unscrew 2 screws in each corner, can't miss them
-unscrew 2 screws behind the A/C knobs
-pull entire assembly out and up
-unplug clock
Discussion Starter #4
i cant find the 2 screws under the ac i found the 2 screws on the side...i took out the shift and unscrewed two screws on the right and left side...now im stuck i cant find any other screws
Did you take off the ac knobs? all of them including the vent one. 4 knobs all together. They are behind the temp one and the one that you select for feet etc..
:werd:
1 - 7 of 7 Posts
