221 - 240 of 240 Posts
the images from the 1º post are gone it will be great if someone could upload them again
regards
I've made some research and it appears no one knows what the units are. I guess I'll have to figure it out by doing datalog comparing maf voltage and a/f ratio against air flow numbers.
What I'm trying to do is to relate load with air flow, that way it should be easier to find pulsewidth for a target a/f based on air and fuel flow numbers.
Regarding Load on the pfc this is what I found:
Air Flow Correction (AFC)
Defines eight MAF sensor voltages and associated Air Flow percentage corrections.
Air Flow Curve (AF)
Defines 32 MAF sensor voltages and the associated volume of air that enters the engine. This curve models the engines volumetric efficiency (VE[17]) with the throttle wide open (WOT[18]).
LOAD calculation
LOAD = min (2^15, (AFC * AF) / RPM) * (2^14))
Notice that the maximum LOAD is 32768 (= 2^15) and that this is also the maximum practical LOAD MAP Reference[19][20].
http://deletionpedia.dbatley.com/w/index.php?title=A'PEXi_PowerFC_(deleted_20_Apr_2008_at_01:52)#LOAD
Nevermind, I just realized there is a target a/f ratio function integrated in the datalogit software. I think I'll just need to calibrate the air mass flow numbers to match actual a/f ratio to the target a/f.
PowerFC seems like a long time ago, I had Boosted 2.0 tune mine.
I actually have a Datalogit in trunk of my car...
I think I still have the disc for it also.
Who wants it? I'll let it go cheap since i do not have car or PowerFC any more.
Turbo 2zz
the OP is no longer active and the links have been removed from the external host so you will not be able to retrieve them. I suggest referencing an RX7 fc website. they are very active in PFC as well
I am tuning my 1zz with the PFC. i have some lean rich issues at waming up with low load between 800 and 2400 rpm.
it looks like every time i shut down the engine, and later on i start the engine is react different. Or its more rich than the last session or more lean.
SO i want to use the O2 feedback (i had it off all the time) for more safety, but when i switch is on, first its ok, but when i start to drive the engine is shaking. If i stop it keeps shaking at idle. If i switch the O2 feedback of the shaking is gone.
Is there an explonation for this behavior?
Bring on the 12's...
You'll need to adjust the correction factors in the top left corner of settings tab 2 - when the coolant level is cold, the correction factor will amend the fuelling until the next temperature breakpoint.
I'm not familiar with O2 feedback - I don't use it.
Yes i know. Whats your values ? Jesse said the defaults are way to rich. I use Jesse his value And Have already make them a little richer, maybe not enough.
And the spreadsheet ?
Can anyone re-upload the spreadsheet? The link in this sticky doesn't work anymore, and i'm stuck with the tuning my PFC without this file.
Baas,
If you have all the INJ values at 1.000 O2 Feedback will not work properly, can be the cause.
At the correction values for temperature one very important thing is to have the the right values allways higher then the ones to left.
1.000 1.030
1.030 1.040
1.040 1.060
for the first tree (most important) this values work great for me.
sheers
2005 Corolla XRS
DDPerformance Race Manifold
Apexi Power FC
NGK laser Iridium Plugs
Knife Edged and Lightened Crank MWR
Flat Faced Valves MWR
10k RPM Springs MWR
Stage 3 Cams MWR
Moroso Oil Pan
TODA Oil Pump
H Beam Forged Rods
New Stock Pistons
Increased Compression 12:1
HKS Dry Flow Intake 3"
PPE Redliner Supercharger Header One off with 3" Exhaust Flange
3 Inch Full Exhaust w/straight flow custom muffler SS
MWR Pulleys
Dayco Serpentine Belt
PowerBond Balancer
Fully Balanced Bottom End
Q45 Thottle Body
Radium Engineering Fuel Rail
Lotus 440 CC Injectors
OEM Water Pump
Fidanza Fly Wheel
SPEC Clutch
toyota celica vvti
hello!
Can someone please share the Jesse IL excel file? the link has fallen :(
That would help me a lot...thank you very much
