ok i cant get the center counsol and the other panels close to them out...i have taken out all the screws that i can find...i tired to search on this but couldnt find anything...can someone help me out...thanks
Well for the center counsol what I find easiest is to get a flat head screwdriver and start to gently pry it starting at the window switches and make your way down equally on both sides of the gear shifter.
*if you have a manual you'll need to unscrew the shift knob.
*Then unplug the cig. lighter.
*Once that's out, there will be two screws to help hold on the climate control panel on. Unscrew those.
*Then pull off the knobs for the climate control and also the slider knob to control the fresh air or recycled air. There will be two more screws you need to remove.
*Once that's all out, just continue to pry evenly on both sides all the way up to the clock. Once you get to the clock, you'll have to unplug it.
That's it, it's very easy. As for the rest of the dash, I have no idea. I've never taken it apart. Hope that helps.
