1 - 20 of 94 Posts
How To Remove The Intake Butterfly by Jason Bly
<table border="0" cellpadding="7" cellspacing="0" width="65%" align=center>
<tr>
<td>
<font size="6"><strong>Taking Out The Butterfly Valve</strong></font>
</td>
</tr>
<tr>
<td>
<img src="http://www.newcelica.org/other/installs/butterfly/install.jpg" width="653" height="385">
</td>
</tr>
<tr>
<td width="100%">1) Ok first thing you need to do when
taking out the butterfly valve is to unhook the negative
battery terminal. I like to wrap something around the
cable so it can't make contact with any metal by
mistake!!</td>
</tr>
<tr>
<td width="100%">2) Unplug the Mass air sensor wiring
first that is on the top of the air box towards the
intake tube. See diagram.</td>
</tr>
<tr>
<td width="100%">3) Pull the large and small vacuum hoses
off of top of air box to (see diagram).</td>
</tr>
<tr>
<td width="100%">4) Slide sensor off of air box that has
two vacuum hoses and wiring attached to it. See diagram.
(the two hoses and wire can be taken off to leave sensor
attached to top section of the airbox also.)</td>
</tr>
<tr>
<td width="100%">5) Loosen the clamp that is around the
intake hose and attaches to the air box. (Phillips
screwdriver) push the intake tube towards the back of the
car to slide tube off.</td>
</tr>
<tr>
<td width="100%">6) Release clamps from the top of the
air box that are shown in the diagram.</td>
</tr>
<tr>
<td width="100%">7) You should now be able to lift the
top of the air box by gently working it off towards the
back of the car. (there are groves on the front that it
rest in)</td>
</tr>
<tr>
<td width="100%">8) Take out the air filter. </td>
</tr>
<tr>
<td width="100%">9) Pull off the hose that is attached to
the butterfly valve and plug the end of the hose up!</td>
</tr>
<tr>
<td width="100%">10) Slide the Butterfly valve straight
up. It has two clips on the bottom (can be reached by
hand under bottom of intake) that need moved slightly to
allow the butterfly to come loose.</td>
</tr>
<tr>
<td width="100%">11) Place the butterfly hose back in the
same slot that it came out of. As to not interfere with
other moving parts of the motor.</td>
</tr>
<tr>
<td width="100%">12) Place Air filter back in air box. </td>
</tr>
<tr>
<td width="100%">13) Place top half of air box in proper
position. Make sure no wires, hoses, or clamps are stuck
in between top and bottom halves. This may take a few
moments to slide air box in proper location. Makes sure
it is sitting in slots towards the front of the air box
before going further.</td>
</tr>
<tr>
<td width="100%">14) Re-clamp the top of the box, with
the three clamps.</td>
</tr>
<tr>
<td width="100%">15) Reattach large hose and small hose
to air box.</td>
</tr>
<tr>
<td width="100%">16) Slide vacuum sensor with the Hoses
and wiring attached to in back into the original slot.</td>
</tr>
<tr>
<td width="100%">17) Reattach the intake tube to the air
box and refasten hose clamp. </td>
</tr>
<tr>
<td width="100%">18) Reattach the Mass airflow wiring to
the Mass air flow meter. </td>
</tr>
<tr>
<td width="100%"> </td>
</tr>
<tr>
<td width="100%">Note: My self or Newcelica.org are not
responsible for damaged, lost, or misplaced parts, and/or
incorrectly following steps. If you are unfamiliar with
engines or are not mechanically inclined I suggest you
get help from someone with prior experience or better yet
a professional. If you have worked on engines and or
familiar with working on engines then you show have no
problems. This guide is designed to help someone easily
find key areas and parts too aid in the removal of the
"butterfly" valve. If we in anyway can improve
this handy, "printer friendly" guide please
email myself @ <A href="mailto:[email protected]">[email protected]</A> Thanks, and
enjoy!</td>
</tr>
<tr>
<td align="right" width="100%"><strong>Jason Bly</strong></td>
</tr>
</table>
I just did this on my 00 GTS and man you can really tell a difference - not so much in the first 3 gears, but from 4th on the pull is noticeably better. The engine sounds great (probably due to the greatly less restricted airflow) and the exhaust tone is meaner. Great free mod - takes 30 minutes, and doesnt generate CELs or anything like that. I would imagine a slight gain in MPG as well.
I concur. I loved this mod. I think on an auto its a good mod especially because i get alot better throttle response and less hestitation when pressing the gas. Not for sure about the gains but the sound comes to life right at 3000 rpms in an auto. Nice buttery deep resonating engine purr!
Maybe it just my imagination.....but my imagination is LOVING this mod! Not sure how much faster this translates as far as an ultimate test like a 0-60 time, probably not much at all, but from inside the car, the throttle response seems WAY quicker...obviously sounds better too!
Quick question for those of you who did this a long time ago.....I'm thinking that this butterfly valve is basically an automatic choke....and at engine startup a choke is closed so that you start with a rich mixture...I'm in Southern California, so it probably wont' make a big difference, but how does the car start in a cold climate without the valve?
This is a sweet lil mod. It opens up the intake quite a bit and it was really easy to do, about 20-30 minutes.
I noticed a appreciable power increase and the engine got a bit louder! =)
In response to BlueRice about this valve performing a choke in cold weather... I dont think this device performs that function considering it runs off a vacuum tube, this would mean that it requires pressure to rotate the valve. Considering that at startup engine pressure is lowest, i dont think it would do a very good job of restricting or allowing airflow to provide a more rich mixture. My guess is that this is a noise reduction device...Higher RPMS = more pressure = more sound thus rotate the vavle to sort of baffle the sound as the engine revs more....
but thats just my $0.02
i just did this mod today, and yeah i can hear the difference and it does feel much smoother when shifting
NVM its just cuz the battery was unpluged,
Wow i dont notice a Power difference but definitly in the auto transmisition,
I remember when i would floor it it wouldnt shift for like a few seconds, and now it does it RITE on the nail! worth doing if u have an auto
Does this turn on the Check Engine light due to more air over gas ratio? Anyone have there check engine light turn on since?
Thanks for the info - just want to know of it turns on before foing this Mod.
Check Engine turned on after less than 400 Km's after this mod - Ha#ve to check the code to see if its related; But DAMN does this suck in more air. I love the mod!
Keep you posted on the code that comes out.
1 - 20 of 94 Posts
