1 - 7 of 7 Posts
As the title says. I only have the hotchkis rear street sway so would a TRD front sway be a good match? I also have an APR Front strut bar and a TRD rear bar, TRD Springs and KYB GR2 shocks/struts
any front sway would be better than stock, you will feel loads of difference. Imo you should try to find a hotchkis street to compliment the rear but a trk would be ok. Check how thick the front hotckis is compared to the trd and see if you can get stiffness % for both. That will give you some idea how the trd will compare with the set.
Well, how does your car react at the limit. Is it pretty neutral, oversteer or understeer? That would bring the first question you should ask : do I need a new front sway bar?
I do not know if I will ever need one but currently, a front one would make my handling worse imo. I only have a rear one (St which is even stiffer than yours) and I believe that's the best I can do with sways so far. FWD cars tend to understeer too much! Bigger is not always better! I am talking about sways of course :)
Suspension advice from a drag racer.........and I agree :chuckles:. What is this world coming to?
:rofl:
I am now converted to solosport! :evil: I am also the fastest in str8 line there .. :eek:: lol!
And the person who converted me is Many :)
1 - 7 of 7 Posts
