:werd: You do need help.pads shouldn't be a problem and if the rotors come off as easy as on the celica, the rotors shouldn't be an issue either. Don't forget to bed both the rotors and the pads. And bedded in pads are better to bed in new rotors and older rotors are better for bedding in new pads.beth said:I just got some Rotora cross-drilled and slotted rotors and need help installing them and new brake pads! Can anyone help me out on Saturday?
Seriously, the celica rotors were about ready to fall off when Slava and I changed my pads. :laugh:Originally posted by boostjunkie26
I can't imagine the rotors to need more than a rubber mallet to loosen up. Either that, or the little bolt hole to "jimmy" the rotor off.
Is there an online tutorial on the Tibruon's brakes? Particularly the rears. I just want to make sure the rear caliper doesn't need a "special" resetting tool (like the damn vws!).
Funny because mine were the exact opposite. I had to wack them with a rubber mallet a thousand times before they loosened up.Originally posted by kaioshin
Not enough miles?larryd said:Funny because mine were the exact opposite. I had to wack them with a rubber mallet a thousand times before they loosened up.
depends on the pads and how hard you are on your brakes.Originally posted by schlegelbagel
How many miles do you usually go through, before you need new brake pads?
:werd: Just bed in the pads on the old rotors first, then the next day you can install the whole mess, and re-bed.kaioshin said:Don't forget to bed both the rotors and the pads. And bedded in pads are better to bed in new rotors and older rotors are better for bedding in new pads.
ir really depends. I replaced the pads and rotors on my bimmer, they were stockers. I figured with 70k miles on the car, it was time for a change and I got all 4 corners (pads and rotors) for 250. When I took it all off, the pads were maybe 1/2 worn, and I saved the rotors, I can resurface them and they'll be fine.schlegelbagel said:How many miles do you usually go through, before you need new brake pads?
