1 - 3 of 3 Posts
This is the deal.. I bought a 2zz with a damaged socket for the ac compresor bolts. I use it with only 2 bolts. well after a month the the bolts came loose & the belts trashed the power steering went out also. I only drove it for 2 blocks parked it & towed it to the shop. Well the Shop could not guarantee any weld work on the block because of the ammount of pressure on the bolts to the block. So they recomended I remove the ac compressor & run a smaller belt. The guy assured me there would be no affect to engine at all.
Well now I picked up the car while I wait for the company I bought the engine from to replace it & the same day I took out the car the heat gage read I was overheating then I turn off the ride & it goes back to normal then It does it again after say 30 min of driving. I look under the hood & everything looks ok??????????? Please help!!!
you need to bleed the cooling system, you have an air bubble in there
1 - 3 of 3 Posts
