so far i'm going to get new brake pads and get an alignment. What else should i do for a tune up? All ideas are welcomed. Maybe change all my fluids in my car.
? sea foam how do you do that and what is sea foam?Blue Bomber said:- Run Seafoam through the intake, oil, and fuel systems
- Check your spark plugs
- Clean/replace your air filter
- Bleed your brake and clutch lines
- Clean your MAFS and IAC
Not at all, though you'll need two people. Just have one person go to a caliper, put one end of a vinyl hose on the bleeder plug and the other into a container. Then pump the brakes a few times, hold the pedal down, and have the other person open the bleeder valve to drain out the fluid. Close the plug, release the pedal, and repeat till the fluid is clean and bubble free. You'll want to start from the caliper furthest from the driver and work your way forward.Originally posted by LowcarbonBLue
ahh..sparkplugs...nice ideas bomber...is bleeding your brake lines hard?
Seafoam is a cleaner made of petroleum. You just pour it in through the PCV line into the throttle body to clean out the intake system, pour it into the oil to clean out the oil system, and pour it into the gas tank to clean out the fuel system. I've heard nothing but good reviews about it, and some people have even gained considerable gas mileage (EasyC for one) after using it.Originally posted by george
You just pour it in with the oil you already have. It frees up all the sludge and deposits that have formed.Originally posted by LowcarbonBLue
so you actually put seafoam IN your gas tank, and oil system? Do you have to drain the oil then put it in, or just put it in with the oil already in it? Thanks.
The only reason I can think of that you'd want to put it in before an oil change is it could fill up your filter pretty quickly with all the gunk it loosens up. Seafoam is made of pure petroleum, and is 100% safe to use, unlike the average solvent cleaner.Originally posted by dmaxd03
As for sea foam in your oil, do it right beofre a oil change. You dont want that stuff in your oil for daily driving.
Yup, same as with discs all around.Originally posted by Lord Banshee
Which wheels would you do on a GT(DRUMS)? Rear Pas, Rear Dr, Front Pas, Front Dr. in this order.
I believe there are measuring instructions on the bottle. If not, they're on Seafoam's site:Originally posted by Lord Banshee
For the Seafoam.. Is it best to buy 1 can and divide 1/3 oil, 1/3 gas, 1/3 intake?
Yup, it goes into the hose on top of the throttle body. Just yank the hose off from the valve cover while the car is running and slowly pour in the Seafoam.Originally posted by Lord Banshee
For the intake which hose on the throttle body? I am not sure which one is the PCV hose and how did you get it in there? Would you jsut turn your car on unplug PCV hose and put it into the seafoam and let the vaccum suck it up?
Yup.Originally posted by Lord Banshee
For the oil you just for it in where you do the oil?
