Hey can some one tell me how they got the 2 stock exhaust studs off. If its a certain type of socket or tool, what is it called? thanks
umm.... I used a normal metric socket for the nut and an allen key for the bolt...
I haven't looked at the studs but you can use two nuts to get it off. Screw on the first nut and then the second one on top of that one. Tighten them together and then start unscrewing the first nut. The first nut will press against the second nut and not allow the first nut to move. This will force the stud to move.
he wants the stock stud removed.
What I did to mine was use the smallest socket I can find and made sure it was tight and it works.
