dont drill the holes...just postion it on the hatch part of the car, check for clearance while somebody holds it for you, like if the hatch will open etc. and then just use a little bit of double sided tape, put it back on, when u like the position etc, have the friend hold it, while you take out the rubber grumets from underneath the hacth and drill the screws all the way up. try to center it the most you can ok...and do this before paiting it...dont over tight. then just take it out and paint it etc,
Avenge2c:good to hear you got it perfect....
