MY question is, do i need a special drill bit to drill the holes in the cf hood (its a vis cf hood) ? i was just drilling it with a normal drill bit and it started to crack on the surface. any suggestions?
On my old CF Hood, I just made an "X" out of electric tape and used a regular 3/8 bit and drilled through, worked great and didn't crack at all.
I pressed a piece of wood down on the top of the hood and drilled through the hood into the wood. But you are probably going to want to just take their^^ advice.
