1 - 10 of 10 Posts
has anyone made lighter rods and pistons for the 2zz also has any one knife edged the crank?
Discussion Starter #2
no one?
Discussion Starter #4
what are they made out of?
how much of a power increase will you see with the crower rods and wiseco pistons.
there might be some gains because both the rods and and pistons will be lighter and stronger than the stock ones.
Plus you can order the wiseco pistons with higher compression if you want some more gains. this will require race fuel.
Discussion Starter #7
what are the crower rods made of?
Would I still be able to use pump gas (93oct) if I raise the compression to 11.8-12.0??
How much more hp, tq would I recieve from this??
Are the Wiseco pistons all I need for the installation to raise the compression safely?
What precautions do I need to take??
1 - 10 of 10 Posts
