You car is a 2002 - ECM is different from the 2000 & 2001Hungster said:your telling me that bolt ons dont give you enough power????? well with my bolt ons i got plenty of power, with the kazuma i still couldnt go over 135, my car pulls hard in 6th gear.
My car pulls hard in 6thh too, just not hard enough at topspeed. Air resistance increases with velocity squared. So you need a substantion power increase for a little increase in speed. 135 in 6th means you are reving around 6000rpm. There you are about 30-40 HP below peak power. So you need a dramatic increase in HP at mid range revs, about 10-20 at least, to give you a chance to pull through to reach peak power i.e. top speed at peak power.Hungster said:your telling me that bolt ons dont give you enough power????? well with my bolt ons i got plenty of power, with the kazuma i still couldnt go over 135, my car pulls hard in 6th gear.
Word... I have hit 145+ but have not gone over 150 take ur **** to the max man.... take 5th as far as it can go... push it to the limit and u will see... cld be driver (not clowning but it cld be the way u drive it)aerospike2002 said:Ummmm.....I have a 00 GTS and live in CA. I have hit 148 as well with no problem (at least that's what the speedo stated). And, that's on a flat road - no downhill. I don't know what's up with your GTS.....
Thanks for the hint man, but thats just what I tried rev it to the limiter in 5th and shift fast. I hit 6th at about 6300rpm but it justObseneLogic said:
if you can push the car to 8300rmp that is right about 140ishvatik said:The speedometer becomes inaccurate around 120ish.... Tested figures for a us. GT-S are:
134mph in 5th gear at 7800rpm
132mph in 6th gear at 5800rpm (something close to 5800)
Yeah, guess you're right. The limiter in 6th sets the topspeed.exotic performance said:
