1 - 16 of 16 Posts
I plan on getting my engine plastics and the last plastic that I havent taken out yet is the ECU Cover
Is it safe to open and take off the ECU cover? It has DO NOT OPEN stamped right on to it
Be prepared .... its like the suitecase in pulp fiction.It glows in a mysterious way .. and you can take your eseys off of whats inside.
BTW i always thought that glow was probably a big mac and fries from Mcdonalds.
WillyK said:
It will explode if you open it.
LMAO:chuckles: :rofl:
Just take it off and look, it doesn't do n e thing if u take it off, i just dont recommend messin with the stuff inside.
i've screwed around in mine a bunch of times (installing shift light, powermeter, getting the cover painted, etc...) and it's all good. oh, only thing is be careful putting the bolts back in because i've had them break twice now (apparently i had some really weak ones or something). they were only like 50 cents to replace though.
Just make sure you have something covering your ears it's loud
Yeah, Toyota just doesn`t want anyone tinkering with the components in that box if they don`t know what they are doing since it does contain the all important ECU, hence the warning.
1 - 16 of 16 Posts
