New user!
I just bought some new taillights from andys auto which can be seen here:
http://www.andysautosport.com/toyot...hts/tail_lights/spyder_auto/spyd00109127.html
Ill probably make this way longer than it needs to be so a apologize.
This is what my plans are.. i have no idea about any of this stuff so,
advice and tips are GREATLY appreciated.
Now the install..
The new lights came with the same three holes for my ( reverse, signal, and running/brake lights) PLUS two additional wires..for the LEDS..one ground and one power.
Current OEM:
White 921 bulbs.. no worries! fit good transfer good.
White 7440 ( signal lights)
White 7443 ( running/brake)
In the new lights the 7440/7443 share the same "housing" if that makes any sense. ( lights are essentially side by side)
My plan was to rewire the LED lights to be the running lights..
This would mean that my signal lights and running lights would both be white.. ( white bulbs) ....
The plan was to buy four Red 7440's LEDS to replace both bulbs ( signal and brake).
So one question i have is.. If i have a Red LED bulb as my brake lights..and another one as my Signal lights..right beside eachother.. Will i still have a distinct Signal when i brake and signal at the same time? ..
Or should i buy a white LED for signalling to make it more distinct?
Also i was told to put resistors on the signal lights ( 50w 6 ohm) which i was going to do.. should i also get a resistor for the LED brake light?
Now the install..
Current OEM:
