Hi everyone, hope you are all safe and well.
I am hoping somebody here will be able to assist me in diagnosing my problem Knock sensor P0325 code on my 2000 2zz.
I have searched high and low on several forums for similar related posts but have not come across and answer for my issue.
As you can imagine my symptoms are CEL on dash, ignition retardation for obvious reasons, and occasional misfire depending on engine load (caused by ignition timing i imagine). Obviously under these conditions i am unable to rev over 7k and Lift is non existent... which i so desperately miss!!
Anyway, I have tested the OEM sensor (single pole) fitted as per repair manual and have no continuity through sensor. I have also confirmed that it preduces a small AC voltage when bench tested so assume the sensor is not at fault. After inspecting the wiring loom and jumper cable I detected the wire insulation was damaged exposing the inner core that had signs of water ingress. I have since repaired the wire and tested resistance through harness to pin 27 at E5 connector at ECU - very minimal resistance through wire and of course continuity is present.
With my findings now indicating an ECU issue (pray that its not), I am curious to know if I should see a 5 volt signal to sensor from ECU in order for the knock signal to be calculated? Would anyone know if this is the case? Also, would anyone know where the sensor harness gets its shielding earth from?
Any info would be extremely appreciated.
Thanks in advance Guys.
