Hello,
I have a 2001 celica GT with 225,000 miles.
It runs great. I hooked up the ob2 sensor and a misfire code for 2 and 4 showed up so I replaced the spark plugs and the code went away.
I replaced the pcv valve, pcv hose, ventilator hose, changed the oil and transmission oil. I also replaced the fuel injector seals.
no engine codes come on the ob2 but if I go to the o2 test it
54844
54846
It was showing the same thing before I replaced the oxygen sensors
I bought a dye kit and put it in the engine and the colored dye showed around the oil cap so I replaced that too.
The engine makes this tapping sound if I step on the gas pedal at about 25% it just click click click click but if I give it more gas there is no sound. If I give it more gas the noise isn’t there. If I don’t step on the gas pedal after it’s making the noise the sound doesn’t continue.
It seems if I keep it at a consistent rpm it starts to make that sound. I notice it usually happens around 60-65mph but if I give it more gas there is no noise.
the other issue is the passenger door isn’t responsive to the door lock button and when I lock the car with a key. That and when I’m driving around 75 mph or if I’m making a turn the open door icon lights up and it sounds like the door locks click.
It happened today I was driving on the highway and as I was going faster the open door light would come on
Engine knock? Or rattle?
2000 GTS Turbo
Hello,
it is more of a rattle. I replaced the fuel injector seals about a week ago and I noticed the area was still wet so I took a look at the injectors and some of them were cracked.
54848
Wow
What happened?
Your cracked injectors.
As for the door, I'd check the door open pin switch. If the system sees it as open, it won't lock the door.
