1 - 12 of 12 Posts
Hello guys , I recently purchased a Bee-R rev limiter/ Launch control unit
For my 03 gts , I have a stage 2 clutch.
Where would be a cool or convenient place to mount the small control box
Because you have to be able to adjust it while In the car . So anything in arms reach of drivers seat . I was thinking of measuring and cutting a place in the door above the radio head unit (figured if I botched it I could fkn another one easily)
Any input or experience of a good location :)
Please post more info on your setup. I am wondering what you have tucked away under your hood....
Why not^^?? Well if its stock then I get your point but if badass built N/A or boosted then I would to.
Because launch control is one of the stupidest things ever fitted to any car. It demolishes clutches each time it is used and it is just another aid to help shitty drivers go fast. If you can't properly launch a car then you have no business going fast.
2zz swapped 03 celica gt.
Any chance you mounted it and could share what wires you tapped into I’m having trouble finding the ignition signal it looks like we have one for each coil? Plz help
1 - 12 of 12 Posts
